BMR Releases New Product: Adjustable Trailing Arms for 5th Gen Camaro - TCA033
Old 03-06-2012, 01:08 PM
BMR Tech's Avatar
Talking BMR Releases New Product: Adjustable Trailing Arms for 5th Gen Camaro - TCA033
BMR Suspension
Adjustable Trailing Arms for the 2010 Camaro and Pontiac G8
Eliminate wheel hop on the street and launch harder at the strip in your Fifth Gen Camaro or Pontiac G8 with a set of Adjustable Trailing Arms from BMR Suspension. Superior to the factory stamped steel arms, these Adjustable Trailing Arms are constructed from 1.25” DOM steel and 3/16” CNC laser cut mounting plates. Factory trailing arms can cause wheel hop, inconsistent handling, and decreased braking ability under load. The BMR Adjustable Trailing Arms (TCA033) utilize low friction, Teflon-lined spherical rod ends to eliminate bind and provide length adjustment. When used in conjunction with other adjustable rear suspension links (control arms and toe rods), the BMR Adjustable Trailing Arms allow a wider range of alignment settings for various racing applications.
Installation time is only 2-3 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit BMR Suspension - The Leader in High Performance Suspension & Chassis, email sales@bmrsuspension.com, or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
Quick Reply: BMR Releases New Product: Adjustable Trailing Arms for 5th Gen Camaro - TCA033
