*RELEASE* LG Motorsports G5 Camaro Coil Overs
LG Motorsports is proud to bring you the G5 Camaro coil overs.
MSRP $1295.95
Years of testing the new Generation 5 Camaro platform have let us build a shock and spring package that will make your Camaro come alive on the track and still be completely street friendly. Our shocks feature Camaro specific valving and spring rates. The shocks are built with custom lengths that allow your Camaro to be lowered without running into shock travel problems.
- 22mm front strut piston shaft
- 15mm rear shock piston shaft
- LG Motorsports approved custom spring rates
- LG Motorsports designed and tested valving
- Easy ride height adjustment
- Bolt on installation
- Compatible with all Gen5 Camaros
- Track tested and daily street durable
Ride height
Ride height is simple to adjust with the LG Motorsports coil overs. Simply turn the spring adjuster on your strut/shock up or down to lower the ride height of your Camaro to your liking. This also will allow you to corner balance the weight of your Camaro, something that can not be done with the OEM design.
Track Tested
We have worked for decades on our Corvette systems, and the Camaro is no different. Taking from our years of street and race track development we put all of this into this coil over for your Camaro. Using data from our in house SS and ZL1 Camaros we put together a kit that is easy to install on your Camaro and give you confidence and improved handling both on track and the street.
Spring Rates
Using the data over the One Lap of America, street, and track testing we developed a spring rate that left your Camaro balanced and easy to drive. Both on track and the street you will find a new level of confidence not experienced by even the ZL1. If would like to use these on a custom application please talk with one of our sales reps about possibly changing the springs for AutoX, drag racing, or any possible combination.
Pickup a set of our G5 Sway bars and end links to finish out your suspension package!
Bang for the buck you will not find a better coil over system on the market!
