Gen 5 Camaro Tuning, Diagnostics, Dyno results Tuning problems, solutions, dyno results for Gen 5 Camaro
Which spark plug heat range for 515ish RWHP
Old 08-24-2012, 01:10 AM
jorge516's Avatar
Default Which spark plug heat range for 515ish RWHP
Which spark plug would you guys use on a 2010 camaro with 515 RWHP with a a big cam? I know the stock spark plug is rated 5 for heat range so the next step would be a 6.
Should i apply 1 colder heat range for each additional 100 RWHP or 2 colder heat ranges?
Would you go 2 steps for a:
NGK BR7EF or
NGK Iridium TR7IX
Or well just 1 step ahead to a 6 heat range numbered spark plug?
NGK BR6EF or
NGK TR6IX
thanks for you comments!
Old 08-24-2012, 05:24 PM
DietCoke's Avatar
If its n/a it wont matter. Run the coldest plug you won't foul, which is probably a 7. I like the BR7EFs, I'm running 8s now.
Old 08-24-2012, 05:26 PM
edcmat-l1's Avatar
TR6s will be fine.
Quick Reply: Which spark plug heat range for 515ish RWHP
