Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
Livernois Motorsports September LS3 & L99 Camaro Camshaft Install Package Specials
Old 09-10-2011, 08:39 AM
LivernoisMotorsports's Avatar
Default Livernois Motorsports September LS3 & L99 Camaro Camshaft Install Package Specials
For the month of September, we are offering a vehicle install package for our LS3 & L99 camshaft install packages.
The LS3 package sells for $3,799.00 installed and tuned and can be found here and includes:
  • Livernois Motorsports Stage 2C Camshaft
  • Livernois Motorsports Dual Valve Spring Package
  • (Livernois Motorsports Dual Valve Springs, Titanium Retainers, Valve Spring Locators, Locks, & Valve Seals)
  • Hardened Pushrods
  • Stainless Longtube Headers
  • Stainless 3" Catted Connection Pipe
  • Wideband 02 Bung
  • Cold Air Intake
  • NGK TR6 Spark Plugs
  • GM 3-Bolt Cam Sprocket
  • ARP Cam Bolts
  • GM Exhaust Gaskets
  • Fluids & Synthetic Oil Change w/ Filter
  • Professional Installation
  • Livernois Motorsports Dyno Tune
The L99 package sells for $4,599.00 installed and tuned and can be found here and includes:
  • Livernois Motorsports Stage 2C L92 Camshaft
  • Livernois Motorsports Dual Valve Spring Package (Livernois Motorsports Dual Valve Springs, Titanium Retainers, Valve Spring Locators, Locks, & Valve Seals)
  • ARP Head Bolts
  • MLS Head Gaskets
  • Hardened Pushrods
  • Stainless 1 7/8" Longtube Headers
  • Stainless Catted Connection Pipe
  • Wideband 02 Bung
  • Cold Air Intake
  • GMPP LS7 Lifters
  • GMPP LS2 Lifter guide kit
  • GMPP LS2 Valley Cover
  • GMPP Valve Cover Breather Block-Off
  • GMPP LS7 Camshaft Sprocket
  • GMPP Timing Chain Dampner
  • GMPP PCV Hose for Non-DOD applications
  • GMPP MLS Header Gaskets
  • ARP Camshaft Retainer plate bolts
  • ARP Timing Chain Bolts
  • LS2 Front Cover
  • Synthetic Oil Change w/ Filter
We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules.
We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that you car will make it to our location and back to you safely, and with much more power than it arrived with!
Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer.
Call or PM today to schedule your appoint or ask any questions you may have!
Thank you
Regards,
Rick LeBlanc
Quick Reply: Livernois Motorsports September LS3 & L99 Camaro Camshaft Install Package Specials
