Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
sump removal
Old 10-14-2013, 06:55 AM
hymey's Avatar
Default sump removal
Is there anyother way of removing sump from 2012 5th gen without dropping crossmember or removing engine.
If not is it a big job to drop crossmember.?
cheers
Old 10-17-2013, 02:51 PM
ducatisl's Avatar
6 large bolts hold the k-member in. You'd have to support the motor/tranny/front suspsension/radiator somehow while lowering the k-member enough to drop the pan. Maybe you could use an engine cherry picker to keep the motor up while lowering the member?
Quick Reply: sump removal
