Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
pic of a coated engine bearing for the banana
Old 03-30-2014, 12:35 PM
ls427ray's Avatar
Default pic of a coated engine bearing for the banana
these bearings promised to play nice with the boost and juice. hey..."boost and juice" rhymes. I may be on to something. lol
Old 04-08-2014, 09:31 AM
Camfreek1's Avatar
Boost and juice doesn't rhyme but boost and juiced does.I can't believe you took a pic of the bearing.Too funny.
Old 04-08-2014, 09:45 AM
ls427ray's Avatar
ok...I'm a lousy poet.
Old 04-11-2014, 07:25 PM
Chevy Fanatic's Avatar
What type of coating is that? How thick is it? I assume it must be very consistent in thickness from bearing to bearing in order to maintain crank to bearing oil clearance. Is the coating applied, measured, then crank journals ground to set clearance?
Quick Reply: pic of a coated engine bearing for the banana
