fuel economy of a 4.8l?
so i've been thinking of engines to swap into my S10, it would be a daily driver so fuel economy is by far more of a concern than power.
i rarely drive on the highway, and when i do its not for an extended period of time so i'm mainly looking for city mileage.
the truck is a 95 extended cab S10
3.08 posi
5 speed
weighs about 3300
i've been thinking bout swapping a newer ecotec out of a cobalt or cavalier into it but i've just started thinking about a gen III motor.
so what kind of city mileage do you think i could get out of a 4.8L? heck even a 5.3?
3.08 posi
5 speed
weighs about 3300
I dont think it would get much better than the 5.3, but it sure can't hurt. I have the 4.8 in my 07 silverado extended cab, standard bed, 2wd, and with 3.23 gears it gets 16-17 in mixed driving, best of 22 on the highway. In your set up, I could see it getting a solid 18 with dips into the 20's if the city driving your talking about isn't constant redlights and speeds of 30-45 mph most of the route.
I may be the only one on this, but I would be curious if you wouldnt benifit from a little deeper gear if all your doing is city driving. Keep you in a more constant power band and keep it from lugging. This would depend on what rpm you are usually at driving speeds.
not constant, but there are a fair amount of redlights, depends on if i get lucky or not, and speeds on roads can be anywhere from 30-50, typically the speed limit being ~40-45
i would be babying and trying to shift ~2000 rpm as much as possible, and depending on the speed i'd try to keep them 1000-1500
And if i had i to i would swap a 6 speed in.
what number gears are you thinking?
What happened to the original motor? If the original engine is in need of a replacement, I would just replace the 4 with another 4 cylinder due to fuel consumption. I have 2 S10's and both have the 4.3 V6....its a thirsty beast.
haha it has the 4.3 in it, the vortec with the CPI
originally i was looking for a 2.2 but this truck had everything else i was looking for
and so i'm thinking i can swap in an ecotec and drop 50 horsepower and a fair amount of torque, but gain substantial mileage, or swap in the 4.8L and get a little better gas mileage (hopefully, if i see 21-23 i would be extremely happy) and much more power.
oh i had a 4.3 vortech in my blazer and was getting...well more than i get now HAHA.
I was doing...GOOD city driving? not many lights and the speeds of a couple roads were 45-55 and the lowest was 35, and if i got lucky i didnt hit many lights.
I probably got 20 MPG...because i defiantly noticed a changed in my gas bill once i bought this... I probably get 18 in my z28.
anyway...4.8 in a s10...maybe high teens, low 20s is reasonable, but kinda unlikely.
5.3...high teens
5.3...high teens
Well, both of my s10's are the 4x4 models. I have one ZR2 which I recently took out on a long trip. I had my cruise set at 65mph and my BEST on the road was 18.5 MPG. Granted, I have 31 inch tires and 3.73 in the rear, but the 4.3 is certainly a thirsty. My other is also a 4x4 with the standard 235/75/15 tires, but it is also running a 3.73 rear. My best around town and this is while driving like a dying snail is 17.035 MPG. I always let up at 2000rpm and let the trans grab the next gear for maximum mileage, but this is all I can manage myself. I also have the 4l60e trans in both trucks. I hope that others with the 4x4 drive is actually getting better consumption then me......the 4.8 will drink more....but sound Way Better out back!!!
you really think that the 4.8 would drink more? i mean with my LS1 i get 18-19 consistently, and thats the a 4l60e and 3.23 gears, i figured that the 4.8 being smaller and behind a 5 or 6 speed would yield some better mileage
hm with my 5 speed trans, 3.08 rear, and tires (27")
45 @ 1259
65 @ 1819
if i go with 16 inch rims but a smaller sidewall
29"
45 @ 1172
86 @ 1693
does that sound right?
45 @ 1259
65 @ 1819
29"
45 @ 1172
86 @ 1693
i bet youd get a lot better milage with a 5.3 or 4.8 v8 then you will from your current 4.3 v6 then you think. a big engine moving a light load is more efficient then a small engine moving a big load and in this case for a v8 your 32-3400lb truck is a light load.
thats what i'm thinking, these trucks and SUVs getting ~16-17 city (which is what i'm getting with the 4.3 right now) are at least a thousand pounds more than me.
Theres lots of fairly inexpensive bolt on's you can do to the 4.3 to get better mileage. Electric fans, and UD pulley top the list. And I know everyone thinks 3.08's will give you better mileage than say 3.42's or 3.73's but I've proved this theory wrong on my S10's. I'd dump those.
i noticed that about the gears, idk if its that or the transmission, but in my camaro 4th + 3.23 gears is at a lower rpm than 5th + 3.08 on the truck
I've seen proof of this first hand when 6 or 7 years ago my dad traded in his 95 GMC 1500 2wd standard cab long box, with a tbi305, and 5spd that got 18-19mpg hiway, for a 2000 GMC 1500 2wd standard cab shortbox, with a 4.3 v6, and a 5spd and dropped to 16-17mpg hiway. A small motor in a heavy vehical has to work to hard. then add the more efficent efi setup, more advanced computer, more efficent combution chamber, and coil on plug ignition, and I don't see how you couldn't gain mpg if you keep you foot out of it, and around town I could see you gaining mpg with 3.42 or 3.37 gears with either motor and more so with the 4.3 be cause you'd lug less. I also dout there would be much of a milage difference between a 4.8 and a 5.3
you want a V6 to be 1800-2100 rpm at 60 in OD. 1800 for 2wd, 2100 for 4wd's. I've seen charts online before about this, stating the same thing. But all of my S10's are 2-2200rpm at 60 with the gears i have in them. Great performance and fuel economy for what they are.
