Ls1 swap help
LS1Tech Administrator
Received 1,493 Likes
Yep. There is zero chance of anyone being able to help without more info.
What have you already tried to fix it? What have you verified is working/not working?
What happens when you turn the key? Does it crank? Does it sputter? Can you hear the fuel pump priming at all?
That was my bad i should off put more info . The car does crank but it wants to turn on but it doesn't .if I use starting it turns cranks but doesnt have any spark . I took it to a shop they don't even know was wrong with it . Also I'm not getting spark . I ask the guy if he use the ls1 fuel system he says he has but to me it looks like the lt1
