General LSX Automobile Discussion Non-technical LSX related topics.
oil pump and timing chain set
Old 02-02-2012, 05:51 PM
flattusmaximus78's Avatar
Default oil pump and timing chain set
Car is getting a built motor right now. I am just looking for a oem replacement oil pump.
I cam across these:
http://www.ebay.com/itm/New-Melling-...item46006b44c2
http://www.ebay.com/itm/Chevy-4-8-5-...item589203abd3
They both appear to be the same pump. How do the stock pumps hold up in these cars? In mustangs we can get away with a lot so I wasn't sure. Also if I get one of those, would I be missing anything?
ANNNND timing chains. I heard if you go double roller you need some spacers for the oil pump, is this true?
This is the one I was thinking about:
http://www.summitracing.com/parts/CCA-7106/
This one comes with spacers. So I guess I would just like to know if the two will work together?
Thank you!
