car cutting out at wot
so i had the car out again last night and it was running great. did a couple pulls and was perfect. then i went to do another pull and it started cutting out horrible at wot. couldnt even get over 5k rpm in 3rd. i have had it out several times this year already with all different temperature levels, so i highly doubt it has anything to do with tune. just had it inspected last week and not a single code came up. now this may sound really stupid and i hope this is the solution but the gas was very low. could it just be something as simple as this? car has newer fuel pump in it and i checked all plug wires all were on fine. car idled perfect and drove normal just fine. any ideas?
well now speaking to several more guys, they seem to think it is because of my SD tune. im going to research more into the SD vs. maf setups. i may ditch the SD tune and go to maf, as some guys are telling me SD tunes arent as good and make less power?
LS1Tech Administrator
Received 1,492 Likes
If the problem is at high rpm only and the engine seems to hit a wall at 5k, you may have some weak valve springs that are floating. If ignition and fuel systems check out fine, then valve springs would be my next guess.
well an update. just had the car out with fresh gas and it ran perfect. perfect everytime at WOT and idles perfect and normal driving is right on. no issues whatsoever
