Firewall grommets
Firewall grommets
i'd like to mount my ECU inside the cab & was wondering if anyone knew of a good place to get some rubber grommet to run my harness thru the firewall?
Why not use the one that is already there for the ECU? Once you mount it inside you could run the harness back through the original grommet. Unless I am not understanding.
i guess i should have been a little more specific. i'm doing a swap into my 96 chevy silverado. the factory truck harness has a plug that connects through the firewall.
