I need to get some keys made...Must I get raped by the dealership?
Hey guys,
I got a really good deal on my 01 Z 6 speed with just 75k miles but it only came with a engine key and keyless entry.
I need 2 door keys since I dont have one and a copy of my engine key.
Do I have any other choice other than getting raped at the dealership?
BTW: I live in Orange County, CA.
Thanks a lot !
Thanks a lot !
Hey guys,
Thanks a lot !
Thanks a lot !
the engine key CAN be bought on ebay, as a blank, but you have to find the exact resistance of the key, then match that to the one on ebay.
You can google a car locksmith in your area. Most all of them travel to you, and cut keys and even make new ones if you're missing them. They can do keys that need to be programmed, keys with chips, keyless remote programming, etc.
How do I go about finding the exact resistance of the key?
Location: Your girl's back door giving her the long stroke while you're at work
Find someone with HPTuners or CATS and have them tune the VATS out of it, then you can use a non-chipped key for the ignition
Bypass VATS (vehicle anti theft system) because it has gone bad on EVERY single fbody ever made and Will go bad on yours too.
After the bypass you will be able to use a copy key you got cut for $2 at homedepot. VATS does nothing to protect your car but does complicate your life at oddest times.
I had to get another key made for my car when I first got it, so I went to the dealership, thinking I was gonna get raped too, but the key was only ~$10 and ~$5 to cut it if I remember right. I was confused why it was so cheap, thinking that the black thing on the key was a chip that needed to be programmed. The old guy at the parts counter told me it was just a wire that connected both sides of the key so if someone shoved a screwdriver in the ignition it wouldn't start because it needed the wire to complete a circuit.
Now I'm not saying this is true, I really have no idea, but I was just happy it was so cheap!
LS1Tech Administrator
Received 1,493 Likes
Well its a common problem on any car with a VATS system so not just F bodys. The small wires to the ignition cylinder key reader like to break from the turning of the key & cause a no start. Replacing the ignition cylinder or wiring in the proper resistor will get the car up & running again. Thats usually all that goes wrong with the VATS system. I had it happen on mine last summer.
I know it is a problem... But to say it WILL go bad is kind of silly.
We have just came up with 25 between me and rpm that had zero problems. I would say that is enough to say it isn't common enough to tell someone that it is going to happened one day regardless.
Me too. Had the VATS act up on my Denali for the 2nd time back in March. Was stuck out in the rain until I was able to get to a dealership and get it taken care of. Needless to say the VATS is tuned out now.
