slowin down
slowin down
installed a 9 inch rear in my car with 3.89 richmond gears and a spool with 31 spline axles. I had a stocker with 3.73 gears. My car is a 02 ws6 m6. Seems like the car slowed considerably with the new rear, sounds crazy, i know, but does the 9 have that much more rotating weight and mass to cause this?
OP may be on to something. The 9" has more parasitic drag than a 12 bolt. I am not sure how noticeable it is though. Chevy High Power or GM High Tech did a test that included these two rears and maybe a couple of others too. My memory is that the 9" had the most loss through it by a large margin. Obviously it is very strong so it is a good choice, can't remember how the 12 bolt compares to it strength-wise...
Yes, because of the offset pinion, the 9" has the most parasitic loss. Acording to the article that Jeff Smith did in chevy hi performance, the 9 inch had a 10 hp disadvantage compared to the 12 bolt. Eric L
