Pontiac Heater Question
Hi,
I have a 1992 Grand Prix that's always been a great car. Suddenly, the heater works (warm air good) and fans work (range of speeds 1 thru 4 also good) and the Off switch works in terms of shutting off the fans but the problem is that it doesn't matter if I push the button for 'heat', 'vent', or 'defrost', etc; the air is pretty well split between the floor and the windshield and never goes full floor, full vent, full defrost, etc.
Here's a picture of the control: http://home.nctv.com/ajns/92GrandPrixHeaterControl.jpg
Has anyone else run into this problem? I'm wondering if it might be a relay somewhere that I can change to get the proper heat switching where, during these cold months I can get heat through the vents on the dash and so on. So have any of you guys seen this?
TIA
Hi,
TIA
