can i run backward exhaust on ls engine ??
hi im new here !!
im planning do a v8 swap on a bmw.
so i cheking what are option and i see some people do mustag 5L swap and run 2 shorty passenger headers !!
it is possible whit an ls engine ??? because this is a cheap solution do avoid doing a 3u-joint sterring shaft or custom headers !!!
thx im happy to know that because i prefer do a ls swap than old 5L fsi even if this one is really cheap
what kind of problem can occur ?? exhaust leak ?? or broken header ??
because i will never put a turbo on this is just a way to bypass the sterring shaft issue, an ls is enough powerfull for me this bimmer will be my daily drive so i plan around 400hp
Your best bet is to spend some time in the conversions and hybrids section , many documented builds including BMW in there.
That's where this type of conversation usually takes place and it is extremely active section where you can get advice from people that have done swaps
