General LSX Automobile Discussion Non-technical LSX related topics.
Help! Car leaks!
Old 06-09-2013, 04:14 PM
MeMz's Avatar
Default Help! Car leaks!
My car is soaking wet after in the carpet on the drivers side only. The passenger side is dry as a bone.
It's an 02 SS w/ t-tops. I've checked the t-tops and they do not leak, I've resealed the windshield and the plastic trim around it.
My windows seal to the top of the door frame, so what else could cause a leak? Any common areas?
Old 06-09-2013, 07:06 PM
transambroli's Avatar
Had the same problem on mine with the drivers side rear carpet only. I simply stopped parking facing downhill in the driveway and only park facing uphill and have not had any problems since. Not sure if that helps you but here's some reading
https://ls1tech.com/forums/general-m...vers-side.html
Old 06-10-2013, 05:08 PM
MeMz's Avatar
Thanks for the response. I've been searching the forum and come across similar threads, but I haven't really found a definite answer for my situation yet.
Old 06-10-2013, 05:14 PM
MeMz's Avatar
Thinking about stuffing a towel in the corner of my t-tops to see if that helps, or if it gets wet to see if its leaking.
I'm looking right now on how to check them I guess, still looking how to fix it though.
Quick Reply: Help! Car leaks!
