General LSX Automobile Discussion Non-technical LSX related topics.
Rpm gauge doesn't work after motor swap, pls help!!
Old 06-13-2013, 06:00 PM
00_z28camaro's Avatar
Default Rpm gauge doesn't work after motor swap, pls help!!
In my 99' Pontiac T/A a4, I put a new motor in my car hooked everything back up as they should be, all new sensors in the motor. And in the instrument panel all the gauges work except the rpm gauge, when ignition is turned over the needle moves to the zero mark and stays there till I turn the car back off. I tried checking my grounds replaced cam sensor and still nothing
Someone please help a poor desperate fellow trying to get this fixed!
Thanks everyone for the help,
Chase
Old 06-14-2013, 11:49 AM
Zfan's Avatar
You sure the Tach signal is set for a 4cylinder?
Quick Reply: Rpm gauge doesn't work after motor swap, pls help!!
