General LSX Automobile Discussion Non-technical LSX related topics.
Block length...
Old 09-01-2013, 10:35 PM
lsdart's Avatar
Default Block length...
Hope this is the right forum for this question....what is the length of an LS block? Going to mount it using a mid & motor plate so I am wondering what the distance will be between the plates....Just curious...
Old 09-02-2013, 09:36 PM
JD_AMG's Avatar
Did you try a search yet?
https://ls1tech.com/forums/generatio...learances.html
Old 09-02-2013, 10:23 PM
lsdart's Avatar
Originally Posted by JD_AMG
A length is indeed mentioned in that thread but it does not specify where it was measured to/from.....I did see that before I asked....
Old 09-03-2013, 06:25 PM
JD_AMG's Avatar
Im guessing from the longest point, end to end of the block.
Heres more things google pulled up:
https://ls1tech.com/forums/6190165-post2.html
http://www.pirate4x4.com/forum/gener...imensions.html
https://ls1tech.com/forums/conversio...imensions.html
http://paceperformance.com/p-3990-en...imensions.html
Old 09-03-2013, 11:00 PM
lsdart's Avatar
Thanks...I spent close to two hours a few night ago when I could not sleep hunting on Google and did not find squat. As a guess the plate to plate distance is probably 20.5". Thought about looking for a plastic mock up block but the damn thing is more than a bare block on FleeBay. Not to mention the car was set up for a 2G HEMI using a plastic block...I borrowed a friends HEMI only to find out that the plastic blocks dimensions were off...Anyhow, Thanks again for your help....
Quick Reply: Block length...
