ls1 kinda cut out
ls1 kinda cut out
not sure how to explain it didnt quite feel like gas issue or spark
left my buddys house did a burnout had plenty of power got almost home some kid wanted to race figured why not went to punch it from the stoplight bogged down let off gas punched it again took off like hell shifted to 2nd it bogged again like i could feel the motor running but just no power took a few seconds for it to come back and had all the power back again ill check my codes tomorrow only code iv been throwing is cam sensor high output voltage ( bad solder joint i think) other then that iv had no problems
any other questions let me know
also motor is a 99 out of a camaro has had all emissions deleted and 5 pin maf swap and has headers i sent the ecu to a guy to tune out the emissions and he adjusted the fuel stuff for the 5 pin maf could that be a possible cause?
its in a 90 240sx
walbro fuel pump and FPR is set at 58 psi
its in a 90 240sx
