General LSX Automobile Discussion Non-technical LSX related topics.
plugs n fluids
Old 03-14-2015, 04:54 PM
buddy35thle's Avatar
Default plugs n fluids
Im bout to buy new spark plugs, engine oil and transmission fluid as part of the cam swap im doing what plugs n fluids do yall recommend. For what its worth switching to a torquer 2 cam and yank ss3600 stall thanks
Old 03-14-2015, 11:02 PM
ULTIMATEORANGESS's Avatar
Smile
m1 for your engine and dexron ATF.
Old 03-16-2015, 11:11 AM
McGinnis's Avatar
As far as oil goes just check for the GM4178M oil spec on the back of the bottle in 5w-30 or 10w-30 if it's an LSX based engine, Pennzoil Platinum, Castrol Edge and Mobil One synthetic, all meet that and are reasonably priced and good quality.
Old 03-16-2015, 01:04 PM
mjs1012's Avatar
I use NGK TR55 plugs, Mobil1 0w-40, and just basic Dex3 trans oil. Make sure you get a good trans cooler for when you put in the converter.
Old 03-16-2015, 09:56 PM
I ordered a b&m transcooler to go along with the stall. How many quarts of dex3 would i need? Thanks for the info
Old 03-17-2015, 08:09 AM
mjs1012's Avatar
I'd get like 11 or 12 quarts and drain the trans completely and refill it.
Old 03-17-2015, 06:30 PM
Smile
id get a deeper pan for added cooling.
Quick Reply: plugs n fluids
