How much does it cost to mod.
You have a 2002 Ls1 with an A4 and put down 290rwhp, which is a 12% powertrain loss. Your built tranny and rear is ready for any thing you throw at it.
1 engine ($2500)est. + $500 for tune
________
cat-back exhaust($450+$150)
Lid ($100+$100)
25% UD pulley ($250 + $200)
Ported TB ($120 + $200)
1.85RRs ($600 + $250)
325rwhp est.
$85.71/hp
2 engine ($3000)est. + $500 for tune
________
cat-back exhaust
Lid
25% UD pulley
Ported TB
cam ($400 + $1000)
345rwhp est.
$63.63/hp
3 engine ($7800)est. +500 for tune
________
true dual set up($600)
headers ($600 + $450)
LID
25% UD pulley
90mm Intake/90mm TB ($1000 + $250)
Heads ($2500 + $350)
cam
418rwhp est.
$64.84/hp
4 engine ($8000)est. + $500 for tune
________
cat-back exhaust
Ported TB
EPP D1sc Procharger kit ($6000 + $1200)
460rwhp est.
$56.66/HP
5 engine ($10800)est. + $500 for tune
________
cat-baxk exhaust
LID
ZL402 ($8500 + $1500)
500+rwhp
$53.81/hp
6 engine ($18000)est. + $500 for tune
________
cat-baxk exhaust
LID
ZL402 Low CR ($8500 + $1500)
D1sc Procharger ($6000 + $1200)
700+rwhp
$43.90/hp
So in conclusion from this, the more you spend the lower the dollar price per horsepower. Do you all think this estimation is right on target?
________
Lid ($100+$100)
325rwhp est.
$85.71/hp
________
cat-back exhaust
Lid
25% UD pulley
Ported TB
cam ($400 + $1000)
345rwhp est.
$63.63/hp
________
LID
25% UD pulley
cam
418rwhp est.
$64.84/hp
________
cat-back exhaust
Ported TB
460rwhp est.
$56.66/HP
________
cat-baxk exhaust
LID
500+rwhp
$53.81/hp
________
cat-baxk exhaust
LID
700+rwhp
$43.90/hp
not to mention, if you do it as you mod.. usually you end up upgrading already bought items.. which in turn is wasted money in the hp/$ ratio.. itll kill it fast.
Not to mention alot of people put in supporting mkods that add no hp at all.
Doesnt look like you took into consideration tires/wheels.. suspension mods etc.
Didnt include any of the new twin turbo systems they have blowing around.
Though the built tranny/rearend was mentioned.. but what's that run installed? 6k? parts and labor. hurts hehe
The first two builds wouldnt need the suspension rear/tranny mods.. though when you start hitting the 400+ range then you need them.
LS1Tech Administrator
Received 1,492 Likes
start with gears and a stall(if your tranny doesnt already have it)
Then get heads/Cam/boltons Run you anywhere from 2500-4000 depending if u buy used or new parts and where you buy them.
Search is your friend!
Your car runs pretty stout for a stock A4.
your car runs very stout for a A4.
How much ultimately depends on which route you wanna take. What you expect from your car, and many other things.
Try searching the dynometer section, and using the search.
H/C/boltons run you anywhere from 3000-4000 for everything and ultimately if you are going to perform the labor yourself.
Good luck. This is a very expensive/addicting hobby.
