An Odd thing
Old 03-31-2009, 08:49 PM
RedHatRdRacer's Avatar
Default An Odd thing
2002 Camaro SS 5.7 A4
You can be driving down the road no problem, All gauges fine....
then at the same time the Volt meter pegs on 18 ABS INOP BRAKE and AIRBAG come on....
BUT
You can turn the AC on and they go right away and everything goes to normal
No SES lights or codes pop up
Any Ideas?
All the grounds are connected, and the battery is new... My thoughts point to an Alternator Problem but I would like to know IF anyone has had this problem... and how its fixed
and I do understand that it could be the computer could be cutting them off due to them being options but i was thinking that was on low voltage
anyway thanks in advanced for the help
Old 03-31-2009, 09:33 PM
IHATEMUSTANGS's Avatar
I had sort of the same prob on my 98 T/A. It didn't have a/c but would peg the gauge and light up the warning lights. I replaced the alt and checked and cleaned all the grounds and it went away. Nit sure if its the same thing, just thought I would pass on the info.
Old 04-01-2009, 12:04 PM
anyone else?
Old 04-01-2009, 01:05 PM
NonGoggleGuy's Avatar
Alternator / battery / connection / regulator. Something in the charging system for sure.
