Common for newly installed injectors to sap a bit?
I installed new injectors in the LT1 and upon first startup, the o-ring seals were leaking just a bit on every injector. Is this normal?
Thanks beedo and NonGoggleGuy for your helpful responses. It ended up that a few of the injectors had defective pintle caps and were leaking before the lower seal, so the fuel flooded upward out of the injector opening. So I bought new injectors and I expect everything to be fine.
