Electircal Problem?
Old 04-29-2009, 11:51 PM
The Golden One's Avatar
Default Electircal Problem?
Hi hows it going? I wanted to see if I could get some feedback on a problem I am having with my 98 camaro z28. About a month ago I would try to roll my windows up while driving or idle or just period and when I would hit the window button all my electronics would go off. Just the driver side power window button. I could do it from the passenger side no problem, some time passes it stops and now when I park my camaro and pull the key and open the door the radio and power(lights, window power) are still on. Normallly when u pull the key and open the door everything goes out. So I experimented and it only goes out when I open the passenger door! Has anyone experienced similar problems? Any advice would help... Thanks!
Old 04-30-2009, 07:10 AM
duh
duh's Avatar
sounds like either a door switch or a ground wire/ short circuit in the door itself (probably around the window switch
