ac porblem help!
Old 04-30-2009, 03:10 PM
camarokid239's Avatar
Default ac porblem help!
so my ac just went out on me, but the compressor is still running and i checked my free on and it is full...what else should i check so it can start running again?
Old 04-30-2009, 03:46 PM
2001NBMZ28's Avatar
How did you check it? What was the static pressure and running pressures?
Old 04-30-2009, 11:08 PM
NBM-LS1's Avatar
The compressor will not run without enough pressure in the lines so you know that you have a charge. Unless of course you have no idea wether the compressor clutch is spinning and not the compressor itself.
