installing power antenna
Need help. I have a new power antenna, with no instructions. The antenna has 3 wires. Does anyone know the operation of each of these wires, which is for up which is for down and the negative wire? This is going into a 00 Camaro.
When I did mine I had a ground and two other wires. I hooked the ground up and then hook the other two how I thought they should be and then turned the radio on and watched what happened. The first time it went up but wouldn't come down so I swapped the two unknown wires and it worked fine the second time. That was it.
