Question about O2 sensors...
Old 05-12-2009, 01:38 AM
SKZ28's Avatar
Default Question about O2 sensors...
I have a '98 Z28 with almost 94k miles. I'm not sure if I need to replace the O2 sensors or not. The car runs very strong and never gives me any problems. Gas mileage isn't great, but with the way I drive I'm not surprised.
Anyway, when I bought the car a few months ago, the previous owner told me that the "passenger side o2 sensor needs replaced" but he never bothered to replace it because the car still ran fine regardless. The car has been dynotuned and the o2 code was tuned out, the car runs very strong and the SES light never comes on. The car does have longtubes, not sure if it matters in this instance or not.
I'm wondering if I should even bother replacing them, knowing that the passenger side o2 is bad. Would it even make a difference? It doesn't seem to be affecting anything.
Old 05-12-2009, 02:05 AM
LS6427's Avatar
If you had a bad 02 sensor you would know it, the engine would run HORRIBLY. I had one fail 2 months ago and the engine ran like hell and would not stay on at a stop light. I had to keep pedaling it to keep it running. It stumbled badly under acceleration too.
If you want to, go get a scan to see if the sensors are switching properly. Either they work or they don't usually, but you can also have a failing sensor. But like I said, you would know it FOR SURE.
And you need to get scanned by a real OBDII scanner like the dealerships use, not the orange little ones at auto parts stores.
ALSO.....a bad 02 sensor will NOT always give you an SES light.
Old 05-12-2009, 09:41 PM
SKZ28's Avatar
Yeah, I was just told by him that it was bad, not sure how he knows or what lead him to believe it needed replaced. Thanks for the response!
Old 05-12-2009, 09:53 PM
LS6427's Avatar
How did he know it was bad?
Like I said, if you have a bad 02 sensor the engine is going to literally run like ****. Spitting and sputterinmg and running very rich, with no power.
So how does he know its bad.
Old 05-12-2009, 10:07 PM
SKZ28's Avatar
Good question. I'll have to ask him next time I talk to him
Old 05-12-2009, 10:17 PM
LS6427's Avatar
So did you buy a new sensor and put it in?
If you didn't, get a scan first so you don't waste your money.
If the car is running perfectly, there's no way on gods green earth you have a bad 02 sensor.
