Speedo issue?
Speedo issue?
Im having kind of a wierd problem with my speedo, when i go WOT it will jump up and down rapidly instead of keeping steady as i row thru the gears. Other than that and any other time driving normal, half throttle or even 3/4 throttle it doesnt do it. Im not sure what to make of it.. Any thoughts?
You're issue is close to mine only mine jumps around at idle when I'm not moving, and fine otherwise. I'm guessing it's something to do with one of the grounds. That's about what I'm down to but I don't have the drive to start looking at all the grounds associated with the dash.....all I can say is Good Luck and hopefully someone here has had a similar issue.
