Multiple problems, A/C and battery or alternator?
Old 07-30-2009, 05:39 PM
anchov13's Avatar
Default Multiple problems, A/C and battery or alternator?
So heres the situation, I go on a road trip coming from Washington, through Idaho, down to Las Vegas and off to LA. The day before I leave Idaho I changed the oil and accidently left the car in the ON position as i finished. So I leave, forgetting its in the ON position I drained the battery.
So in the morning I jump start it and started my road trip. It dies a couple times when I stop for 20+ minutes for gas/food, no problem I get jump started. So I roll into Nevada and the A/C quits on me, SUCK. I drive through 115 degree weather with the windows down, back sweating profusely.
So the battery died again as I left my hotel, I get jump started and leave to LA. The A/C is still broken. So right now I'm in LA and I figure I need a new battery, so I go out to the car and it starts up with a little lag, probably 2 seconds. And while its idling, its at 2.2k RPM =/
I give it a little gas hoping it would return back down to 800-900k as it should be. But it revs to 4k and slooooowly returns to 2.2k. I put it in drive and it slams into gear, pull forward 5 feet, then put it in park. I figure what the rip, turn it off and start it back up, it idles normally. So I figure I will try to fix the A/C, so i go to the schrader valve and put a gauge on it, 110psi! I drain it down to normal and try filling it up with R-134a. Fill it to the recommended PSI and it still blows warm =/
So I have no clue what's going on? What do you think? My A/C is not working and maybe my battery is bad? Alternator? Condensor? Evaporator? I have no clue, help me!
Old 07-30-2009, 10:05 PM
fleetmgr's Avatar
When you put the gauge on it, was the engine running or not?
Old 08-17-2009, 11:50 PM
anchov13's Avatar
the car was on when i put the gauge on.
Old 08-18-2009, 08:26 AM
dragonrage's Avatar
Normally your car should be able to run without a battery, but the battery could be dead and be sucking all of the juice out of your alternator.
But most likely the alternator is dead, or perhaps both.
If your car starts via any means, and it dies due to lack of power, at all, then you have a problem with your battery or charging system. No exceptions. "It dies a couple times when I stop for 20+ minutes for gas/food, no problem I get jump started." -- wrong. You should have known better.
Old 08-18-2009, 08:33 AM
fleetmgr's Avatar
What was the ambient temperature? You say you drained it down to normal, but normal is a moving target, depending on the outside temp. Then, you say "try filling it with refrigerant" when it was already "over full"?????? I don't get it.
You have a problem, but not with the quantity of refrigerant in the system. Does the compressor clutch engage? Did you evacuate the system? Did you look to see if the condenser is plugged with bugs and crap? Need more info.
Old 08-18-2009, 08:45 AM
dragonrage's Avatar
Note that too much refrigerant will make the system work very poorly.
