lower ball joints which way to press them?
Old 08-02-2009, 11:27 AM
TA4life's Avatar
Default lower ball joints which way to press them?
ball joints which way do these get pressed out? up or down? thanks
Old 08-02-2009, 11:46 AM
02 35thLE's Avatar
I didn't look at mine but they should be pressed in from the bottom. So to remove it you need to press from the top. Most of the time if you support the lower control arm you can use a big hammer to get them out.
