WTF My Low beam wont turn on??
So I saw that i had a burnt out low beam on the drivers side so i went and bought a new one and replaced it. Well it still didnt work, so i started checking the fuses and they all checked out. Anybody have any ideas of what else i can check, or a better was to trouble shoot the problem? Thanks
Have you checked to see if you get current at the headlight connection with a multimeter.
Could also be corrosion inside the plastic connector. I know I had to scrape mine off a bit when I changed headlights.
im having the same problem, both of mine are out. Im pretty sure its corrosion related. The headlight clips are the first place i started looking. I think i may just hardwire mine together to eliminate that stupid connection, its given me nothing but problems.
