Doing clutc. Should I Replace Rear Main Seal?
Doing clutch. Should I Replace Rear Main Seal?
Just wondering if I should replace the rear main engine seal while I have access to it. My car has 70k miles on it. The seal looked great and dry when I first pulled the flywheel off but now after two days of sitting I notices a tiny bit of oil around the bottom of the seal concerning me. Is it hard to replace these?
Oh I see what you mean now.
I didn't even think about removing the housing.
I just used a seal puller and screwdrivers to remove the seal.
Then I used a seal driver and a very large socket to install the seal.
I thought replacing the rear main seal was easier than replacing the seal
on the front timing cover. I found it to be a pain to get that one off.
I did the front while installing my cam.
GM has redesigned the rear seal, it's different from the original unless
you get a Felpro it will be the same. I ended up with the GM seal...
so far so good after almost a year.
