no brake light in cluster
the brake light on the gauge cluster do not turn when hand brake is engage. does anyone know where to check to fix this problem? any help is much appreciated. i search but nothing seems to be related with this problem.
you may want to search under daytime running lights. alot of people bypass their drl module which effects the brake light on the dash. there are a couple posts. just something to look into. hope that helps
