Camaro not starting
Camaro not starting
Car isn't starting. Its cranking but motor isn't turning over.
Car has new ICM, spark at coils & wires so I am thinking its not spark issue.
I checked the schrader valve (pressed it with a pen) but no fuel squirted back out.
Does it only release fuel from the rail with a pressure gauge?
If theres no fuel at the rail, does this automatically mean the pump is dead?
Ended up being my fuel pump. I replaced mine with the walbro 255, and as soon as we put it back in, it started right up. I'd check your plugs/wires first though, maybe one or two is loose.
Plugs and wires are good.
I thought it was an ignition issue so pretty much traced it through all out n it has spark.
I had the car in the garage today in dead silence and didn't hear the fuel pump at all.
I 'll spend more time testing fuel pump relay, fuel filter and pump.
Thanks for input Scira, I 'll keep this thread updated on what I find.
