Anyone use "Pro Blend" additives?
I purchaed some Seafoam and will perform the "cleaning" to the engine, but I had posted this question a week ago, and really didn't get anywhere--- has anyone used Pro Blend additive? Please let me know what your impressions are.
I wouldn't use any of it unless they had independent lab veriifed test results to back up their claims, and showing that the tests were conducted IAW ASTM standards.
Just from the web site, it's all snake oil like the 10,000 other products identical to it out there. NEVER put additives in your oil!
One of the side effects of additives is separation and sludge build up. There was a thread not too long ago about someone who couldn't get the oil to drain out of his pan. There was another thread where a guy pulled his oil pan and found a pile of blue goo in the bottom. Save yourself the headache.
The only positive effect any oil additive can have is to the bottom line of the huckster that's profiting from the sale of it.
I used to think of additives as an "automotive placebo", but they are actually worse than worthless because they can cause damage.
The only thing that belongs in your oil pan is oil.
I agree, but even if you have an independent test was it with the brand/weight oil you plan to use? Every oil manufacturer already puts an set of additives in the oil. You have no idea how this stuff will interact with your oil. Buy quality API rated oil and leave it alone.
You're absolutely right, let the API rating tell the tale.
