heat vents not working
Old 11-05-2009, 02:03 PM
BA.TA's Avatar
Default heat vents not working
My heat and a/c only blow out of the defrost and floor vents no matter where the dial is set to on my 96 t/a. Anyone ever have this issue before? Are there any switches or plus that i should check out? Im not really sure what to look for.. Thanks.
Old 11-05-2009, 03:45 PM
fleetmgr's Avatar
All the heater box doors are controlled by vacuum, so you may have a leak. Check the hose coming off the back of the intake, if it's ok then check all the plastic fittings along the way going to the dash selector, which is actually a valve. Then it goes to the actual vacuum motors on the doors inside the heater box.
Old 11-06-2009, 09:45 AM
2001NBMZ28's Avatar
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
