what size nut...........
What size nut fits the tranny cooler threaded head stud.
I'm talking about the threaded piece thats inside the radiator that sticks out through the tranny cooler port....then a washer goes over it and then that octagon looking kind of nut goes on it to tighten it. When you tighten it down it pulls that threaded head outward and up against the inside of the plastic tank to seal it.
I need to get a real nut that I can tighten down better. Coolant started squirting out of that thing yesterday. Its for the bottom tranny cooler port right under the lower radiator hose.
Does anyone know if there's a rubber gasket/o-ring on the inside.....if so I might be screwed.
