turn signal/ DRL bulb..
anyone know the number like ex.) 4107 that's suppose to be used for the DRL's? i'm re-doing the actual socket on both left and right DRL's because they have both gone out due to the cracking and water getting into them hopefully it's a simple fix, i just got the replacement sockets today.
I wanted to make sure i'm using the right bulb's because last time they got instantly hot, is this normal???
Save the manuals!
Yea - its normal. The heat chars up the sockets real nice. If you have a water problem, you might also want to check and make sure your lenses aren't cracked. (They can take a beating from road debris.)
