Washer Fluid Leak?
Washer Fluid Leak?
I got my 02 T/A back from a repair shop recently and they disconnected a hose or something... when i try to use the washer fluid nothing comes out. it makes a sound so i tried holding it down to see if it was coming out somewhere else and sure enough, it's leaking out from under the driver side fender. i was curious if anyone knows where that hose runs so i can repair it without taking half my car apart.
From the tank to a tee under the cowl. I think the tee is in the middle of the firewall under the cowl. If a hose on the tee comes loose, it could leak outbehind the front wheels. Also, check under the tank, but if it was off there, it would all leak out.
