What to do?
Old 01-16-2010, 01:27 AM
LeftySS's Avatar
Default What to do?
Well was getting the ol' knock sensor low voltage code, so I pulled the intake to change them out and found oil down in the rear KR sensor hole. Pulled the valley cover and replaced the sensor grommet. However, the plug for that sensor had oil on it. So can I just clean it with some spray electrical cleaner or do I need to get a new harness? The harness is in perfect shape except for this.
Thanks.
Old 01-16-2010, 08:50 AM
blade2222's Avatar
just clean the oil out it should be fine. I've had sensor contacts covered in oil and they still worked.
