Help! Car shakes at certain speeds
Old 01-17-2010, 01:48 PM
SixShooterCam's Avatar
Default Help! Car shakes at certain speeds
Alright so I found out my alignment was off cuz it ate up the inside of my tires so after I got wheels and tires I got my alignment done. Keep in mind before all that my car would shake at like 60-70 mph and then 80+...
So after the alignment when im driving straight my steering wheel is off to the left a bit and it still does the whole shaking thing, could it be my tie rod and ball joints or could it be something else?
Old 01-17-2010, 03:21 PM
Greekey's Avatar
If you hold your steering wheel completely straight, and your car veers to the right or left its your alignment. If you hold your steering wheel completely straight and your car does not veer right or left but shakes, its most likely a tire balance problem.
Old 01-17-2010, 04:28 PM
jam01's Avatar
if the shop you went to did an alignment on your car with worn parts, that is a shitty shop. they should also have aligned your steering wheel so it is straight.
Old 01-17-2010, 05:53 PM
yeah they didnt align the wheel... before they did the alignment the wheel was straight but after it got jacked up... Also when I hold my steering wheel completely straight it will veer to the right... I have to hold my steering wheel to the left in order to keep the car straight
Old 01-17-2010, 06:29 PM
DarkJuggalo's Avatar
i would take it back and have them give you the money back and go elsewhere to have it done properly
Old 01-19-2010, 03:08 PM
im taking it back to them today to have them re align the steering wheel
Old 01-19-2010, 03:34 PM
snkeater's Avatar
have them also balance your wheels
Quick Reply: Help! Car shakes at certain speeds
