car wont move
Old 03-27-2010, 03:47 PM
383camaroz28's Avatar
Default car wont move
So i took my car out an got on the highway, doing 40 then all of a sudden car just revs an doesnt move, got the car home an the DS isnt spinning, when i put it in drive it wants to go so i ddont think blown trans, maybe i blew my fuddle converter? Any help would help
Old 03-27-2010, 04:27 PM
the_merv's Avatar
Was any of your gears slipping? Will it move if you turn the car off them back on? Try putting it down in 1 and see what it does then.
Old 03-27-2010, 06:19 PM
All gears just rev someone said i mitea broke tail shaft or input
Old 03-27-2010, 07:05 PM
MIKEY'S 2002 TA's Avatar
Default won't move
hi, same thing happened to me and it was the transmission pump. replaced the pump and now i have all the gears.
Old 03-27-2010, 07:26 PM
Do i have to pull the trans out? Also wherr you buy the pump
Old 03-27-2010, 08:35 PM
fleetmgr's Avatar
Yup, trans has to come out. The pump is the first thing you see when you take the converter off. However, before you just spend a bunch of money and it be the wrong thing, you might wanna put a gauge on it and see what the line pressure is first.
Old 03-27-2010, 08:56 PM
where do i put the gauge to check the pressure?
