Radio and windows
Radio and windows
OK so the problem is, when i was driving today my radio randomly shut off and also my windows stopped functioning and when ever i hit a bump it would turn back on and so on and so fourth.
I'm guessing it is some sort of wiring problem and was wondering if anyone has seen this or had this happen, just let me know if you have any advice or suggestions
Thank you,
Nick
Thank you,
Nick
yes i have seen it happen before, i fixed it. your going to have to check the fuses and the relay's, make sure none are loose. then go to the wire's and ground's.
Wow, third ongoing thread for the same problem. Root cause is your BCM follow this link and you will hopfully find the cure.
https://ls1tech.com/forums/general-l...blems-fix.html
