broken oil pan bolt
Old 04-01-2010, 05:52 PM
Chevellecamino69's Avatar
Default broken oil pan bolt
the rear bolt from the oil pan broke there is still thread in the hole will it leak or do i have to re[lace it
Old 04-01-2010, 06:48 PM
blue98Z's Avatar
If it's one of the main pan bolts then yes it will leak and yes you'll have to replace it. If it's one of the 2 13mm bolt that go throught the bellhousing then it probably wont leak.
Old 04-02-2010, 02:55 PM
its one of the 2 of the back of the pan
Old 04-06-2010, 02:10 AM
found ouy why the bolt snaped tyhe rear 2 are 106 inlbs not 18 lbs
