What does this sound like?
I noticed a louder than normal tapping noise from under the car. Its up by the header collectors area. I dont remember it being this loud before. Turn up your volume all the way and listen closely to the tapping noise. What does it sound like?
http://www.zshare.net/audio/7565366681aac525/
No I didnt change anything. I did long tubes and ory a couple months ago but the sound wasnt that loud. Im hoping that it was just a leak at the collector. I was under the car today and I re installed the bandclamps. I used high temp gasket maker around the joint and put a big bead inside the clamps. Im waiting 24 hours for it to cure and ill start it back up tomoro to see if it was just a leak at the header collectors. Hopefully its not engine realated.
Oil pressure is seems fine
From your description, a leaky collector, or loose header bolt, maybe driving it caused a vibration that shifted the exhaust system and temporarily sealed it, it will pop up again if not tightened.
