Directional Lights Fuse Keeps Blowing!
Hi guys,
My directional lights didn't work(Hazards do work), so I checked the fuse and it was blown, so I replaced it with a new one(20A) and after 1 hour, it still blew again!, So my fuse keeps blowing. Where should I check to stop this problem?
Thanks you very much,
Any help is appreciated!
Wiring! I would start at the front housings as they are subject to a lot of abuse. My fuses were not blowing, but my bulbs were. I would sometimes get a day out of a fresh bulb. The corrosion inside from cracks in the housing caused the bulbs to fail. This is not your problem but being at the front of the car and subject to road debris, I would start there.
