V6 Camaro Spark plug and wire help
Old 05-12-2010, 04:48 PM
redcamaro4140's Avatar
Default V6 Camaro Spark plug and wire help
hey i was wounding is it hard to do the spark plug and wire on a v6 camaro the 3.8. I need to know the best way to do it and the easy way. So i need the help please.
Old 05-12-2010, 08:10 PM
FiredUpZ28's Avatar
If its '00 and up it should have the tubular manifolds, in which case it is very easy. If its 99 and under its got the logs its a little more of a pain, just because of the small amount of room. You may be able to get at some of them from the bottom as well.
Old 05-13-2010, 12:55 AM
Its a 1999 camaro. so its going to be a pain in the *** that what your tell me.
Old 05-13-2010, 12:47 PM
myk
myk's Avatar
Just give it a shot. Either that or take it to a shop and lose yourself $500 or some other ridiculous amount right away...
Old 05-13-2010, 12:53 PM
Choppers's Avatar
They only plug you might have problems with are the #6 one. The rest can be done in 20 minutes with just a simple spark plug socket, ratchet and extension. Wires are easy. Take one off at a time.
Old 05-13-2010, 02:45 PM
I will try when i get the lift for it.
Old 05-13-2010, 03:02 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Agreed, it's just #6 that will likely be a headache! The others are quick and easy!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-13-2010, 03:52 PM
Is #6 on the right side and on in the back.
Old 05-14-2010, 12:42 PM
Choppers's Avatar
yes.
Old 06-26-2019, 04:30 PM
Alex Camron's Avatar
I have a 98 camaro and the #3 plug is impossible to get to even from the bottom.
Old 12-03-2019, 02:16 PM
turbojettajmo's Avatar
#6 is just as easy as the rest. Coming from below the vehicle, take your socket off of the ratchet and use a 3/4” wrench to torque the socket instead of the ratchet. Every spark plug socket i have ever seen has a base shaped to mimic a 3/4” nut specifically for vee and boxer/pancake engine applications where there isn’t enough clearance for a ratchet.
Old 12-06-2019, 04:48 PM
LilJayV10's Avatar
I'm gonna say man up and do it yourself. Regardless of how "hard" it is to do.
Or pay someone.
This post was in jest. Everyone calm their ****.
Old 12-10-2019, 06:07 PM
LETZRIDE's Avatar
If you have headers and stubby wrench to accompany your regular ratchet / socket set you can get it done in about 30 minutes or less. If this is your first time doing it expect about a 6-8 hour job lol
Quick Reply: V6 Camaro Spark plug and wire help
