Power window issue with passenger side?
Old 05-25-2010, 08:51 AM
92SilverSHO's Avatar
Default Power window issue with passenger side?
POWER MIRROR i mean!
Basically, i can move it up/down and to the right. However when i move the stick to the left, nothing happens so its moving in 3 directions and not 4?
Any ideas?
Old 05-25-2010, 04:09 PM
Rychen's Avatar
lol how do you get your windows to move left and right? j/k (post reads windows)
try popping the little panel your window and mirror buttons are on out and check the connections then you might try spraying a can of compressed air down in where the buttons are to get any loose dust out then use some contact cleaner sprayed in the same place.
doesn't take long for a little bit of water from a rainey day to corrode the connections enough to be a PITA.
hope that helps some.
