A/C issue......help!
98 formula. When a/c is turned on, loud metallic noise.It changes pitch with rpm. A/c will still freeze you out, but is still noisy. Suggestions? a/c clutch? How expensive to have it fixed? Thanks in advance..........
it is more than likely your ac compressor clutch. you will need a clutch tool although i would just change the whole compressor. you will more thank likely have to pull the compressor to replace the clutch. for the extra money it just insurance.
