How much vibe do you have after poly mounts?
Old 06-08-2010, 01:34 PM
HoLLo's Avatar
Default How much vibe do you have after poly mounts?
I put in a Prothane trans mount, and a Energy Suspension TA mount, along with some UMI LCA relocation brackets on a few weeks ago. And on the highway at about 80 my vibes are way worse than it ever was. It's actually worse when I let off the gas. I did grind a small layer off the top of the TA mount to get the clamshell to close better, but it's still a very tight fit. I was wondering if anyone else has a similar experience after putting in poly mounts? Or has suggestions if these vibes are coming from somewhere else? Thanks
Old 06-08-2010, 01:43 PM
Drew24's Avatar
Yeah my polly mount did the same thing but i have herd that taking the metal plate off and grinding the side of it will cut down the vibration. Mine was annoying at first but i kind of got use to it and it beats ripping tranny mounts every time i go to the track.
Old 06-08-2010, 01:56 PM
HoLLo's Avatar
You must have an ES poly mount because they have the metal plate unlike the Prothane. But I do believe the ES is a little softer it seems.
I know my car is in need of an alignment, but this came up until after these mount installs. This would probably be better in the suspension forums.
It did have the initial vibration at low speeds after the install, but those went away, and softened up. But now the vibe at 80 is pretty bad. It's odd because it's worse when I let off the gas.
Old 06-08-2010, 02:05 PM
projectX's Avatar
What the hell!? You upgrade mounts and you get crap? Why bother I say.
Old 06-08-2010, 02:07 PM
HoLLo's Avatar
It makes it more solid, it definitely feels better when racing, but during casual cruising, you feel where it's solid even moreso!
KevinR's Avatar
Its not crap, its common when you go to poly mounts. I have ES poly trans mount and yes, i get lots of vibs. I took off the plate as well, and it seemed to calm it down a bit.
Old 06-08-2010, 02:38 PM
Joshiedoom's Avatar
Poly engine mounts and stock trans mount. NO Vibrations.... NONE
Old 06-08-2010, 02:45 PM
KevinR's Avatar
Oh, I should have stated that I have the stock engine mounts.
Old 06-08-2010, 06:27 PM
projectX's Avatar
Sorry> They prob are more stable but I don't wanna deal with vibration issues.
Old 06-08-2010, 10:25 PM
99Bluz28's Avatar
Take the Prothane trans mount off and get a Energy Suspension mount, and grind down/remove the two preload bumps, then install it w/preload plate.
Problem solved!
I run my car this way with the addition of Prothane engine mounts and have very little additional vibration.
Old 06-09-2010, 05:39 PM
Joshiedoom's Avatar
I havent broken my $6.73 rubber tranny after 20 track passes, im thinking if you are, you haveing mount issues with the engine IMO...
Old 06-09-2010, 11:55 PM
HoLLo's Avatar
I'm mainly asking about rear end suspension work. But would prothane motor mounts help me since I've got rubber motor mounts and poly trans mount?
Old 06-10-2010, 12:32 PM
shaun's Avatar
i had a prothane trayy mount with stock motor mounts and it vibed like crazy.
from what i read on here a poly tranny mount dont work to good with the stock mm's.
i got a 1le tranny mount from thunder racing and it has held up for a few years but i think its starting to get weak again.
Old 06-16-2010, 03:49 AM
sjsingle1's Avatar
all poly............no vibes
Old 06-16-2010, 04:05 AM
01 Bad Mutha F*****'s Avatar
Poly motor mounts, poly trans mount --- no vibes
When I was researching mounts I read a lot of info that said it is bad to run poly trans mount with stock motor mounts. Evidently it can damage the tranny if the motor mounts allow to much play.
Old 10-14-2010, 02:13 PM
djatarax's Avatar
I'd love a link for that $7.00 trans mount. I'm pretty sure ES mounts are NOT the way to go. There's almost 10mm difference in height. That vibration you feel... then goes away... could be your extension housing bushings and your pinion bushings/bearings going out. Anybody tried shimming their crossmember to fix it?
Old 10-14-2010, 03:05 PM
X-ray's Avatar
Yeah you're not supposed to have a tranny mount that is more solid than your engine mounts.
Old 10-15-2010, 04:39 PM
DWake's Avatar
I replaced my broken in half rubber one today with the ES one that I ground the bumps and didn't use the plate. Car feels way solid and actually cut about half the vibration in my car. The other half is probably because my bent driver rear rim. The only bushings/mount in my car that aren't poly are my engine mounts.
Old 10-15-2010, 07:01 PM
DWake's Avatar
Oh and about your car vibrating that much, check ur engine mounts. Powerbrake the car to like 1500rpms and if you notice the engine lift too much your engine mounts are going out
Old 10-16-2010, 01:38 AM
ae13291's Avatar
^^ lol is that how you test it?
Quick Reply: How much vibe do you have after poly mounts?
